HOK Marbilizer
Does anyone know how I can slow this stuff down?
I used this marbilizer when it was cool weather and it worked perfectly, now that it's hot and in the 90's it dries so fast I can't keep it wet to put the plastic wrap on it. If it's compatible I may try a universal retarder made for my urethane. Or maybe a real slow reducer. I can't find any info on it. |
Probably not much help but there is nothing in the tech man. about adding anything to increase working time jc. MB is basically a slow drying clear with a lot of pearl. Could be your shooting a too high a PSI or not laying it thick enough causing the rapid drying. Adding a retarder might do the trick as it's been HOT down here lately and quite a few can's of that are going out the door of suppliers.
Other thing would be to work a smaller area at a time. You can wipe it off with grease & wax remover very easy if it dosen't suite you and try it again. Which you want to be carefull with IF you do a pre clean before clearing. Adding reducer would most likely add to it drying so I'd stay away from it. HTH,Mike. |
| HOK UFC35...drying problem, again | theHIGHLANDER | Body - Exterior | 16 | 07-19-2010 05:56 PM |
| HOK Nova Orange | Shakey | Body - Exterior | 4 | 06-02-2005 11:45 AM |
| HOK paint over PPG K36??? | dh79 | Body - Exterior | 21 | 03-04-2005 01:51 PM |
| How much paint for HOK base/kandybase/klear? | dh79 | Body - Exterior | 2 | 02-11-2004 01:26 PM |
| Marbilizer paint? | Bjt | Body - Exterior | 4 | 01-04-2003 01:37 PM |
