HOK Shimrin Metalic Bases - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2005, 12:25 AM
Shakey's Avatar
I am still trying to decide on paint. It seems like HOK Shimrin Metalic bases are no more expensive than Nason.
How bad of a idea is it for a first timer to try to shoot metalics? I presume the FBC woudl be a little easier than the BC?
How transparent are these? Can they be shot over gray primer and look OK, or do they need a white or some other color of sealer under them to look good?
Old 05-24-2005, 12:04 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Go with a GOOD base paint.
Especally being a nubie, I have some experience painting and a silver metallic is the HARDEST paint to shoot. I'd go with HOK over Nason ANYDAY.
See my earlier post on Silver Metalic Blotching a couple of pages back and get educated.
As for the primer,White would be my first choice but I shot over gray.
I don't know that it will make that much difference as long as you get good coverage.
Old 05-24-2005, 04:12 PM
mrcleanr6's Avatar
yes, i agree. go with the hok. its really not a bad price at all. i pay somewhere around $25 - 30 a quart fo the bc or fbc. i usually use white under most hok stuff except the metallics. they come out less blotchy and cover quicker if put over a gray base, especially the silver. i usually use the bc over the fbc. the bc usually covers is 4 coats the fbc will probably be about the same or a little less.
Old 05-24-2005, 04:55 PM
Shakey's Avatar
Thanks guys. Being a newbie and having heard a number of times that metalflake is harder to shoot than a solid, I am a little nervous.
I would be getting the Nova Orange if I go for it.
I went in and talked to the guy at the local paint store today, and he told me I should use Omni, which is the same price I can order HOK for, and if I wanted to go up a step to use (I think it was DBC?) which is nearly twice as much. Makes it seem like it might be worth a attempt at spraying the HOK metallic base.
Old 05-24-2005, 05:40 PM
theHIGHLANDER's Avatar
Listen to mrcleanr6...use HOK and don't look back or second guess what your doing. The main difference in BC vs FBC is the grade of poly (metallic content). BC=base coat, FBC= fine base coat. A finer ground metallic powder for a different "flip" or transition. Also, and this is a huge thing if you think about it, the HOK bases stay fluid for years. Their reducers are all blendable to all their products so compatability is a no brainer. Omni or DBC will harden and turn to junk in a few days or weeks depending on conditions. HOK handles very easy, dries fast, looks awsome, and is the choice of most every top builder and customizer the world over...for a reason. The fact that it's so wallet friendly makes me wonder why anyone would consider anything else for a custom job. Go for it. You'll be glad you did. Think of the look on the faces of those you tell that it's HOK on your project.
Old 05-24-2005, 07:28 PM
302 Z28's Avatar
Originally Posted by theHIGHLANDER
DBC will harden and turn to junk in a few days or weeks depending on conditions. .
What a load of caca, can you offer some evidence for this absurd claim?
Vince
HOK UFC35...drying problem, again theHIGHLANDER Body - Exterior 16 07-19-2010 06:56 PM
HoK Kandy Basecoat and primer questions BigJon Body - Exterior 3 04-06-2005 07:01 AM
HOK paint over PPG K36??? dh79 Body - Exterior 21 03-04-2005 02:51 PM
How much paint for HOK base/kandybase/klear? dh79 Body - Exterior 2 02-11-2004 02:26 PM
