Hole in Braided A/C Line - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 11:23 PM
Recently got my Model A registered and after several short trips I decided to get the a/c charged by my son. When he did a leak test you could hear the nitrogen coming out. Turned out to be a small hole in the Braided A/C line that was running from the Condenser along the frame to the dryer. The only thing it could touch was the fuel pump. My buddy who is in the Radiator business said he sees lots of damage to radiators due to no or poor grounds. I am now adding grounds from the engine to frame, Body to engine, and will connect the Battery negative which is currently grounded to the frame (Batt in trunk) to the engine at the starter. Hopefully this will be enough...Has anyone else seen this happen?.
Old 07-13-2008, 08:22 AM
Irelands child's Avatar
Unless I'm missing something, I can't see any reason for damage to a radiator because of a poor ground - that is - unless you have an electric fan. And even that - many (most) electric fans are electrically isolated from the radiator by a plastic shroud. The 2 rad mounting bolts and the 2 top locating rods should do a pretty good job of grounding and whatever grill shell you have will also be grounded to the radiator. What more can you ask for??
Grounds should always be initially at some engine bolt and should be the same gauge wire as the positive cable. In my case, also an 'A' with the battery in the trunk, I have 1ga wire for both cables and its about 10 feet long. I also have a secondary ground to the frame and a third to the body (a steel Brookville).
Dave W
Irelands child
Old 07-13-2008, 09:24 AM
Poor chassis ground will indeed cause radiator damage, strange as it may seem. I am not sure if it is conductivity though the water or wire inside the hoses but if there is bad grounding from the engine to the chassis part of the current will flow through the radiator. I have even seen it dissolve holes in those cheapy chrome thermostat housings and I know of one case where that happened twice to the same guy. When the T-stat housing started leaking through a tiny hole we removed it and found it had corroded away badly inside and I told him he needed to check the ground cables but he insisted it was just a poor quality housing. About a year later when the new one did the same thing we checked the ground straps and found he had none hooked up and I don't know what the darn thing was grounding through, after hooking up the proper ground straps he later told me he noticed his lights no longer got dim when he turned on the heater. Also it has been over a year since and there still are no leaks in his new T-stat housing!
Old 07-13-2008, 09:43 AM
302 Z28's Avatar
It's a fact people, it's called galvanic corrosion.
Vince
Old 07-13-2008, 09:46 AM
Thermostat housings aren't the best example for a 'corrosion' failure. I have had and have seen many 'way back when' of the pot metal (zinc) and aluminum versions fail, and not always on performance cars. This is usually caused by the pH of the coolant being too far off of neutral, attacking either metal. Usually someone has left their antifreeze in the radiator too long or the fill water is 'off'. In my 'rust belt' part of the country radiators get attacked externally by road salt - and usually the aluminum versions - and another case of pH 'off' on the water that sprays from the road. I wont discuss 2 Subaru's we had in the '80s, but they got expensive
Poor grounds for sure can cause lights to dip, heaters to slow and in electronic cars, poor performance.
Dave W
Irelands child
Old 07-13-2008, 12:17 PM
Thanks for the responses. My Radiator shop buddy says hook up a Voltmeter, Negative to a ground and suspend the Positive probe in the coolant (not touching metal). You will see about 1 volt in an ungrounded situation.
Old 07-13-2008, 12:39 PM
1 volt is enough to cause corrosion and it may be possible that the antifreeze solution works somewhat like the electrolyte solution in a plating tank, whether it does or not I have no idea. I have to agree that any caustic substance would attack that potmetal housing but antifeeze is supposed to inhibit corrosion unless it is old so there are a lot of ifs here. Bad grounding is commonly believed to be one cause of radiator demise but I guess common belief is not proof of fact and many commonly accepted "facts" in reality are not. First chance I get I am going to unhook the ground wires on something and try that little voltage test and if there is voltage present, and I think there is the real possibility there will be, that will be the smoking gun!
how to cut braided fuel line? Longboard Hotrodding Basics 27 01-11-2017 01:41 PM
2001 GMC Jimmy 4.3 > WHERE DOES THIS VACUUM LINE GO ??? FFredericks Engine 8 10-28-2007 09:56 AM
fuel question beach_boy327 Engine 5 10-17-2007 08:34 PM
A/C line crimping tool recommendation. brian0605 Garage - Tools 3 06-19-2007 09:22 AM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
