Hole questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2012, 02:08 PM
Hole questions
In the enclosed pictures, can someone tell me what the threaded holes are for/ One is on the driver's side of the engine and the other two are on the passenger side of the intake manifold. One at the front and one at the rear. Also, isn't the position of the engine, that is, left and right side figured from sitting in the driver's seat facing forward? I know these sound like stupid questions but I have to ask.
Old 06-02-2012, 02:20 PM
poncho62's Avatar
Wiki Edits: 5
Picture 1...The hole goes into the intake runner so you can draw a vacuum from there, possibly for the power brake booster or auto transmission modulator valve.
Pictures 2 and 3 go into the water jackets, hoses to heater or temp sensor etc
Old 06-02-2012, 02:21 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
THe holes are spot to put in heat senders. The rt and lt are as you stated from behind the wheel.
Old 06-02-2012, 05:09 PM
chevynut1's Avatar
No such thing as a stupid question
Old 06-02-2012, 05:33 PM
That is what I have been told. My automotive background was always air cooled, VW's and Porsches. Guess one is never to old to ask questions. My project has been quite an undertaking, but I am up to it.
Old 06-02-2012, 09:17 PM
75gmck25's Avatar
Picture one - the base of the carb has a vacuum fitting (you can see the rubber cap) that is usually used for power brakes, so the threaded hole in the manifold will be the fitting where you draw manifold vacuum for the HVAC controls and for the transmission modulator (like on a TH350).
Picture two - you should thread in a connector here for the heater hose and run the hose back to the heater core inlet. I think this is supposed to be a 5/8" connector, but I've found that a 3/4" connector and 5/8" hose gives me a tighter fit.
Picture three - this is for a temperature sensor in the water jacket. The driver's side is normally used for the sensor that connects to the dash gauge. There should also be a threaded hole on the passenger side, but its often left plugged.
Bruce
Old 06-03-2012, 03:19 AM
V305's Avatar
On the Border
Why in the first picture the PCV is on the back of the intake? is that installed there? I ask there because I have the same intake, maybe I'm getting a false impression
stripped hole by steam hole one 400sbc projectman69 Engine 11 11-06-2011 08:30 AM
2 hole exhaust flange connecting to a 3 hole JLBpontiac350 Engine 0 04-26-2011 01:31 AM
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 06:54 AM
Please help me figure out this hole 1985fiero Engine 9 05-04-2004 04:20 PM
hole saw stea Body - Exterior 9 02-25-2004 10:21 AM
