Hole on rear of block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2013, 09:20 PM
I am building a 4 bolt 350 chevy (3970010) that was manufactured in 1971. While installing an Edelbrock 60899 head on the 1-7 bank I noticed a threaded hole at the top rear of the block that was half covered by the base of the head. Using a probe, it appeared there is a passage between it and place for the oil pressure sender. What the heck is this, and what do I do with it?
Old 03-16-2013, 09:29 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Can you post a picture?
Old 03-16-2013, 09:52 PM
It is above and a bit to the right of the clock symbol on the block. It is about 1/2 exposed.Click image for larger version
Old 03-16-2013, 09:57 PM
anything coming out of it? air? liquid?
Old 03-16-2013, 10:05 PM
Haven't started it yet. Maybe I could get a longer probe and try to figure out where it goes?
Old 03-16-2013, 10:08 PM
BOBCRMAN@aol.com's Avatar
That is an oil galley. There should be a plug in it. If not. Thimgs will get real messy when engine is fired up.
Old 03-16-2013, 10:10 PM
thinwhiteduke's Avatar
Living In The Past
Needs to be plugged.... leads to oil galleries.
Means head off to plug it.
Duke
Old 03-16-2013, 10:15 PM
Thanks to all who responded. Any idea of what type of plug that needs to be put in it.
Sure glad I joined this forum!!
Old 03-16-2013, 10:21 PM
1/4" npt with recessed drive. Common oil galley plug.
Old 03-16-2013, 10:24 PM
Thank you for saving me from a major headache.
Plugged hole in sbc block RatPin Engine 2 08-22-2012 07:44 PM
Hole in the engine block- What to do? TWCarpentry Engine 10 07-27-2011 10:15 AM
Stripped out hole in aluminum block Raidrbabe27 Engine 2 01-09-2007 06:12 PM
cracked starter bolt hole on block fezz-man Engine 7 07-22-2006 01:12 PM
SBC - block dipstick hole? Limey Simon Engine 3 01-30-2003 02:13 AM
