Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - hole saws
Thread: hole saws
Old 08-25-2011, 10:40 PM
timothale timothale is offline
Wiki Edits: 27
Chip clearance hole
When drilling metal it's best to just start cutting to mark the hole location then get a small drill bit and drill a couple holes for the chips to exit, start a center punch just inside the ring then drill a hole thru then change to a bit to enlarge to the ring. If you don't clog the teeth with chips they cut faster cooler and last longer.
