Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 2300 internal fuel leak
  #18 (permalink)
Old 08-14-2012, 07:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Infinite Monkeys View Post
I was thinking I could at least base line the transfer slot for now. What I am confused on is if I take off the carb, can I adjust the throttle plates so the transfer slot is the recommended square’ish shape, or this must be done by looking from the top down. The diagram suggests the bottom up approach.
The transfer slot can be set w/the carb off the engine. The drawing shows what you'll see w/the carb upside down, looking up at the transfer slot from the intake plenum.
So don't set the transfer slot by looking down from the air horn towards the throttle plates. Instead set it by turning the carb over and look at the slot from "underneath".
