holley 2300, what cfm??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2008, 03:24 PM
hi! I just got a new holley 2300 off ebay for my 4.3l chevy. It is new but it didnt come with anything and there was no info so i was wondering if someone could somehow find out how many cfm this thing is. on the bottom underside it has a 5.05 stamp, on the back of the riser on top left it says saej - 1223, the right says 3863240, 75028-1, 0833 and if you were looking straight down from the top it has 6 r 3250 b and 38 underscored. it is a marine carb if that helps. thanks
Old 03-21-2008, 03:40 PM
Jmark's Avatar
according to the Holley site, , it's 350cfm. Might look cool on my lawnmower!
Mark
Old 03-22-2008, 09:23 AM
thanks, i think it is a 350 cfm which I think would be fine for a stock 4.3l v6, huh? but how do you know its the 350 not the 500? thanks. sorry I don't know much about carburetors.
Old 03-22-2008, 09:26 AM
not too bad for $80, and I'm pretty sure the 650 that came off the other motor would be a bit much.
Old 03-22-2008, 02:23 PM
Jmark's Avatar
I "Googled" the number and all I found said 350, including the Holley site.
Old 03-22-2008, 10:57 PM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
__________________________________________________ _______________
C.F.M. = Capable Force Measurement. / Cubic Feet Per Minute ~ So...
Too Big: No Harm ( Unless Jets are too Big.) FLOOD - OUT ENGINE. Low Vacuum.
Too Small: Like a GOVENER, Low R.P.M.s MAX. " Lots of Manifold Vacuum!
The reason it is called a 350... 350 C.F.M. Used in the Center of Tri Power,
With 500's On the Out Sides.
Please Forgive Me:...
0-80787-1 350 2300HP N/A Keith Dorton Circle Track X None 35
0-80583-1 500 2300HP N/A Keith Dorton Circle Track X None 35
0-7448 350 2300 N/A Universal X X Manual 34
0-90470 470 4150 Vacuum Truck Avenger X X Electric 36
0-4412C 500 2300 N/A Universal X Manual 34
0-4412S 500 2300 N/A Universal X Manual 34
http://www.holley.com/data/Catalogs/...arburetion.pdf
Old 03-23-2008, 07:12 AM
Jmark's Avatar
Uh,,,,,,,,??????????????
Old 03-23-2008, 08:04 AM
R E A D... I T... R E A L ... S L O W . . .
Old 03-23-2008, 08:07 AM
Jmark's Avatar
It doesn't make any difference how fast or slow I read it, I do not understand the relevance in this post. Sorry.
Old 03-23-2008, 08:09 AM
DID YOU TRY THE LINK?
Old 03-23-2008, 08:40 AM
Jmark's Avatar
No, gave up after it tried to download 14 megs of crap to my computer.
Old 03-24-2008, 08:28 PM
thanks for the help
Holley 6425 650 CFM 2 barrel lluciano77 Engine 15 01-28-2011 11:26 AM
Holley 850 CFM Vacuum Secondaries.. PITA..!! Viet Nam Vette Engine 18 04-12-2006 07:54 PM
Holley 2300 vs Motorcraft 2100 elliott Engine 3 11-11-2005 12:05 AM
600 CFM Holley Idle Mixture Adjustments. FBody Engine 3 06-01-2004 10:36 AM
600 cfm holley vs 750 cfm holley 85 regal Engine 7 11-27-2002 06:25 PM
