Holley 250 blower too lean on cylinders 1 and 2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2008, 04:40 PM
471A
Multiple engine dyno runs on my SBC 355 with a Holley 250 blower and Edelbrock AVS 800 yielded exhaust temperatures close to 1500 degrees on cylinders 1 and 2 while none of the other cylinders exceeded 1350. This remained true regardless of jetting changes, ranging from .103 to .110 secondary and .113-.116 primary. We also ran the springs and rods which Edelbrock prescribes when the 800 is used with a blower. We suspect that insufficient fuel is reaching cylinders 1 and 2 for two reasons. First, the Holley 250 uses an elongated design. This may be pushing the fuel flow towards the rear cylinders and away from the front. Second, the single carb mounting flange places that carb over the center of the blower. My question is this: Has any among you ran a single carb on a Holley or Weiand 250, but used the dual carb mounting flange, with the rear flange sealed off and the single carb mounted forward ? This would move the carb and its fuel flow forward several inches, perhaps better feeding cylinders 1 and 2. (No, I don't want to run dual carbs.)
Old 09-08-2008, 03:21 PM
You might want to try carb adapter plate Weiand 93153 - it's exactly what you're looking for.
Good luck,
Ran
Old 09-09-2008, 10:34 AM
471A
250 blower too lean
Ran, Wow ! That offset single carb adapter is exactly what is needed. Thank you very much for your expertise and taking the time to respond.
Old 09-10-2008, 01:19 PM
Glad to be of help. Now I need to check if the 250 I have in a box in the garage has the centered adapter or the offset one. It's not going to go on a Chevy (on a small block Mopar instead), but I have a feeling that I might experience the same problem.
Thanks for bringing this up.
Ran
Old 09-10-2008, 01:34 PM
471A
Holley-Weiand tech
After your suggestion, I called Holley-Weiand tech and spoke with a supercharger specialist named "Tom". He said that Holley encourages running the 250 with two small 4 barrels but acknowledged that the 250 can be run on a larger, single 4 barrel. He added that the offset adapter was developed precisely because with a "centered" 4 barrel, the front two cylinders often run lean. Good luck with the Mopar !
Old 09-11-2008, 01:16 PM
Thanks!
Ran
