holley 3310-3 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2011, 12:08 PM
holley 3310-3
where can i find rebuild kit and performance info on this carb?"
Old 04-05-2011, 02:59 PM
Tracy Whitcomb
holley carbs
http://www.holley.com/data/TechServi...%20Listing.pdf
i believe this link will give you all the answers that you need if not go to eHow.com and search identifying holley cabs and there will be a link to the holley caberator reference giude that will give you all the info and stuff on that or any holley carb it will even have the renew kit number and the trick kit number then i would just call my local parts place and if they dont stock them they can order them... hope this helps
Old 04-05-2011, 03:04 PM
techinspector1's Avatar
Wiki Edits: 326
4160 type carb, 750 CFM, #72 front jets/134-21 rear (metering plate), 6.5 power valve
http://www.holley.com/37-754.asp
http://www.holley.com/37-933.asp
Detailed instructions and tuning information come with both these kits. If you wish further information, order this book....
http://www.amazon.com/Holly-Carburet...33692&sr=1-1#_
or another Holley book of your choice....
3310 Mid 60's 780 cfm Holley opelitis5 Engine 1 04-26-2008 08:37 AM
Holley 3310 set up KGRIFF Engine 5 07-28-2007 10:04 AM
holley 3310 metering block joefromcocomo Engine 1 07-22-2007 02:53 PM
what holley trick kit do i need for a 3310-3 carb? tiresmoke55 Engine 11 12-06-2006 11:16 AM
Holley 3310-2 set up help? frankenvette Engine 6 03-19-2005 10:58 AM
