Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley 3310s worth a darn ?
Old 08-07-2010, 08:27 PM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Perfectly fine carb for your application. Can't be easily converted to mechanical secondarys,... but it doesn't need to be anyway, you can get a vacuum secondary spring assortment from Holley to tune the opening point on the secondarys to what works best for your engine. Holley # 20-13, $10.
You will also want a accelerator pump cam assortment kit Holley #20-12 $20, and possibly a larger front pump nozzle but you won't know what nozzle size until you start on-car testing.
You can also convert it to the high flow HP style main body, this is a nice mod to do but not a necessity, Holley and Proform sell the main body kits. Roughly $100. You can improve the stock main body be milling the choke horn off for a good cheap upgrade, this was a real common performance mod before the HP body became available.
Really good carb for all around stree/strip use, I've done several on different cars that run 10 second 1/4 mile times.
