Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley 3310s worth a darn ?
Old 08-08-2010, 01:05 PM
bubbahotep's Avatar
bubbahotep bubbahotep is offline
Had mine for over 20 years and just tore it apart this past week after losing a plastic sight plug inside it. Thing is in perfect shape and easy as hell to tune. The vac secondaries get you good street use and the rear metering plate is a quick adjustment (just swap out the plate for a new one). You can throw on a quick change secondary spring kit for cheap. Mine is on a 9.7:1 383 stroker and the only problems I ever had were my own bad adjustments.
