Holley 390 8007 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2013, 11:49 AM
BadBehavior's Avatar
Holley 390 8007
I'm familiar with Holleys' up to a point. This 390 problem I have not run across before. The gasket I received (Holley kit) does not have the holes indicated (and fits throttle openings well).
from BLPs' site (gasket only pic). These 2 390's came disassembled with no Gasket to refer to. Will the holes make a difference, if so will opening the holes on my gasket do the same job, or is it not needed. Concern is having idle mixture control.
Larry
Old 06-28-2013, 05:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The gasket is correct as-is.
The Following User Says Thank You to cobalt327 For This Useful Post:
BadBehavior (06-28-2013)
Old 06-28-2013, 06:52 AM
Thanks cobalt, Its one of those things if not asked you always wonder, could this be the problem plaguing my tune. I never stop learning something new on these Holleys
Larry
Help me fine tune my 3.4l with a Holley 390 cfm. damanx Engine 14 02-05-2013 08:10 PM
Holley vs Edelbrock for a 390 big block 63BigBlockedMerc Modern Electronic Engines 3 01-15-2013 01:51 PM
Choke tower on 390 Holley 4 barrel Oregonite Engine 2 11-20-2011 01:57 PM
Problem: Buick 231 V6 w/390 cfm Holley chevypanel46 Engine 7 08-30-2008 10:02 AM
holley 390's grapro Engine 1 07-24-2004 08:08 PM
