-   -   HOlley 4150 & 700r4 (http://www.hotrodders.com/forum/holley-4150-700r4-136375.html)
DarknessSpawned 04-04-2008 04:45 AM
HOlley 4150 & 700r4
..What all Do I need to make a 700r4 work with a holley 4150 style carb?
I guess I will need to eliminate the cruise control that used to
be on the 2.hate s10 since it has a 355 now. But still gotta get
the TV cable and throttle linkage to work with a holley 4150..
What do i need? Thanks again :pimp:
barnym17 04-04-2008 07:12 AM
look in your jegs or summit catolog there is a bolt on adapter to correct throttle motion for the cable.That and a throttle cable adapter should do it.
302 Z28 04-04-2008 10:04 AM
Holley makes the proper 700R4 linkage for your carb.
Vince
redlinekink99 08-15-2010 01:43 AM
yea what about the early model 4150s that bracket will not fit, and holley even told me they do not make one
JeffB 08-15-2010 03:04 AM
Get the LOKAR TV cable and bracket and it's a done deal.You can go to Lokars' website to see the install instructions and you will see how it works.
