Holley 4150 Booster Is A Little Loose - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2012, 03:48 PM
I was in the process of firing up my car with this new holley carb & i was looking over everything to make sure every thing was connected & i noticed that one of the boosters was angled further down then the others so i touched it an its a lil loose it wiggles side to side a tiny bit. will this hurt my carb? or should i take it back to the shop where i got it to have them fix it??
Name:	2012-11-25 13.21.41.jpg
ID:	69375   Click image for larger version
Name:	2012-11-25 13.20.47.jpg
Old 11-25-2012, 05:02 PM
If that is a new carburetor I would take it back and tell them to replace it. The other side looks loose too.
The Following User Says Thank You to cdminter59 For This Useful Post:
the82elco (11-25-2012)
Old 11-25-2012, 06:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The boosters should be tight. This is because the fuel is drawn up through them by a drop in pressure (the venturi effect). Air will pull easier than fuel, so if they're loose you could be very lean because more air than needed was being pulled through w/the fuel.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 11-28-2012, 10:01 AM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Yea I have seen several folks with this problem, They wound up epoxying the boosters in. also check the metering block passages for casing flash and the hols for burrs from being drilled.
This wicking 290 Loctite should seal that booster up with no problem
Old 11-28-2012, 10:32 AM
malc's Avatar
Born To Be Mild
I always reckon that if the money I used to buy the
part is good then the part should also be good.
I´d go for a replacement not a fix.
Old 11-28-2012, 02:22 PM
i took my carb back to the shop where i got it from & they took it apart and fixed it
lean a 4150 holley OMARS67 Engine 21 03-28-2012 05:16 PM
4150 holley pena0724 Engine 5 03-30-2009 08:34 PM
HOLLEY 4150 help dawg Engine 3 05-22-2005 04:41 PM
holley 4150 help dawg Engine 1 05-21-2005 07:28 PM
Holley 4150 stevesch Engine 4 06-19-2003 12:52 AM
