Holley 4150 flooding! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2013, 05:05 PM
hey guys, I bought a brand new 4150 600 double pumper carburator last april, it works amazing, this year i decided t try it on my dads truck, its flooding the front shute!! i took it apart and cleaned it now 3 times and set the floats twice. i cant get it to stop flooding, someone please try to help me!!! thanks
Old 04-20-2013, 06:25 PM
33Willys77's Avatar
Whats the fuel pressure?
Old 04-20-2013, 06:29 PM
Proud LOSER
Replace the needle and seat.
Old 04-21-2013, 12:56 PM
Where did you set the floats? Should be just to the point where it starts to dribble out the sight plug.
Old 04-22-2013, 04:32 PM
mustang 671's Avatar
hi . I had the same problem. make sure the needle valves which shut off the fuel are not sticking and are spot on a little tap on the head of the adjuster nut will id if they are sticking as the fuel should stop coming out (no leaks in the float and is getting heavier? ) . too much fuel pressure ? tinniest bit of crap will allow the fuel to flow past .
Old 04-22-2013, 05:20 PM
life is a temporary assignment
The needle and seat are bad for this..
4150, double pumper, flooding, holley
4150 holley pena0724 Engine 5 03-30-2009 08:34 PM
HOLLEY 4150 help dawg Engine 3 05-22-2005 04:41 PM
holley 4150 help dawg Engine 1 05-21-2005 07:28 PM
Holley 4150 stevesch Engine 4 06-19-2003 12:52 AM
Holley flooding LS6454 Engine 3 06-19-2002 12:36 PM
