Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 4160 (3310-S) continuing issues
Old 12-05-2012, 11:34 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Thats what the simple dash mounted ignition power interupt toggle switch is for.
Easy hot starting. Be sure the GM OEM start motor brace is installed.
Why don;t you mark your balancer for 36deg BTDC (1/10th the circumfrence ) and 24deg BTDC (1/15th the circumfrence) of the balancer , from true TDC.
Find true TDC using a piston stop. I bet the timing tab location is out of wack.
