Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 4160/600 CFM Carburetor: Components Identification
Old 03-05-2012, 08:44 PM
cliff tate cliff tate is offline
Originally Posted by lg1969
The PCV port can be use to run brake booster if there is no port on the manifold.
not wise,unrestricted vacume source is esential for pbrakes.re choke the the heat tube should stay closed with elc.choke,the vacume source was only needed when non elctric choke used as it needed a good flow of heated air to expand the coil and open choke
