Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-21-2008, 04:35 PM
62galaxiguy's Avatar
62galaxiguy 62galaxiguy is offline
holley 4160 rebuild question
Im rebuilding a 4160 1850 list for a 390 fe ford because the accelarator pump woulndt shoot fuel when the throttle was worked. Upon dis assembly i noticed under the discharge shooter screw the only part that came out was a steel tubular cylinder about a 1/2 long. The holley rebuild sheet shows a discharge ball and a pointy weight. Is there something missing? Ive rebuilt 4100 fords before and they always have the ball & weight. Can i substitute these parts if they indeed are needed? Thanks
Old 05-21-2008, 05:19 PM
enginejr enginejr is offline
re: holley 4160 rebuild question
I would have to assume thats why the squirter does not sqirt, someone has farmered it up. The pointy thing is pointy so it acts like a needle and seat and will not allow fuel to be pulled out of the discharge nozzles at wot. It needs the pressure of the accelerator pump to lift it of the seat and squirt. The part you took out is garbage, someone probably lost the original piece.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "holley 4160 rebuild question"
holley 600 (4160) on a 331 v8 fourbi4rox Engine 2 09-25-2006 04:29 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 02:25 PM
Holley Carb/supercharger Question subman17 Engine 1 05-19-2004 10:05 AM
Quike holley question Trav Engine 3 10-03-2003 08:00 AM
Holley Carb Question STBR Engine 3 09-01-2003 09:40 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
