holley 4160 vac secs blow back probs ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2010, 03:24 PM
mustang 671's Avatar
hi all. i am in the process od trying to dial in my engine and timing with fueling to start my engine. i have a blown 351w with weiand 671 and 2x 600 holleys.
have sorted the ign at 16d at idel and curving to 28 d all in at 3000 rpm. my engine is really tight to turn over so i am having probs with getting it up to good rpm to start it (has been running breiefly before but timing ws wrong). while i am cranking every now and then i get a blow back through the top of the carb?? is the normal if the engine is turning for a few revoultions without starting with a blower ?
Old 10-25-2010, 12:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
16 might not be enough initial. You can go higher, up to 24 or so if the starter will allow you to, w/o the starter becoming sluggish w/the engine hot.
Total of 32 or so, all in by 2500-3000 RPM or thereabouts.
A lot depends on the CR, the cam specs, how much boost you're making, the blower ratio, etc.
Old 10-27-2010, 12:53 PM
hi guys thanks for the info.
ok i have
jets as . primary = 70s and sec 72s
i have the purple spring in the vac secs
shooters in the primarys have .25 stamped on
i have what i think is the orange cam on the acc pump ( dont think its brown as its too light in colour)
power valves are 65 ( need to check vacum when running to double check they are half of manifold vacum !) they are the anti blow back protected ones, they are not leaking.
i have removed the ball bearing from the vac secs as advised in my supercharger book on holleys (good idea ?)
how much fuel pressure should i set my regulator at ? its at 6psi
also i do not have a dizzy. i have a omex ecu. this is what i have to use below !!
99
90
80
70
60
50 i can put any btdc figures in ( left numbers are throttle and below rpm )
40
30
20
10
00
450-800-1200-1600-2000-2400-2800-3000-3200-3800-4200-4800-5200-etc
so what do you think on a fresh engine just to bed it in and get it running ?
the carbs dont go bang ( like an explosion ) they have pressure coming out of the top which looks like air and fuel mix which is obviously pressurized< is it beacuse its not started and there is a fuel build up and its escaping out the top ??
the engine is very hard to turn. have drained my battery. brand new reallly
ideas ????
thanks all
600 Holley Vac Secs Advise Set Up On Weiand 6/71 mustang 671 Engine 2 10-07-2010 08:53 PM
holley 4160 to 4150 conversion help needed eric32 Engine 10 12-19-2009 05:12 PM
Vacuum advance western star Engine 14 11-30-2009 10:28 PM
Holley 600cfm 4160 headaches kc8oye Engine 7 06-26-2009 07:32 AM
Holley 4160 tuning problem 70bird Engine 6 05-18-2006 06:13 AM
