holley 4412 lower elevation adjustment? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2012, 07:27 AM
Last journal entry: 27
hi all
i just moved from 4400 feet above sea level to 600 feet
and now my stock ford 302 wont even start (it ran fine before the move)
when i first got it off the trailer i was able to drive it around the block but now it wont even do a complete revolution when i try to turn it over.
i loosened the capture bolt on the distributor so i could turn it this way and that.
and now i can turn it over.
please be gentle because the only thing i have ever done to a holley carb was a simple rebuild kit.
Old 05-25-2012, 09:54 AM
jeeze
there are so many possiblities
something may have gotten knocked loose during transport
i dont even know where to start.
loose wires?
air/fuel mixture?
timing?
Old 05-26-2012, 06:30 PM
Update
ok fellas
i figured i better at least give you an update.
since this is a recently built rod and many bugs are being worked out on a regular basis.
i went back to square one and put the dizzy and carb settings back to where they were originally.
then i cleaned the contacts of the dizzy and went along the electrical curcuits tightening every nut etc. i could find.
the engine started first try.
when it gets dark enough to see the timing light easily .
i will adjust that to the best of my ability.
4412 carb or 750 4 barrel quad david73 Engine 0 06-22-2010 06:00 PM
holley carb jet size to elevation ratio mazdaRx7 driver Engine 3 03-16-2010 02:16 PM
holley float adjustment yragat Engine 2 02-11-2007 04:14 PM
need info 5.0 Ford Holley lower intake xntrik Engine 0 09-11-2005 01:20 PM
Holley adjustment Bad Rat 414 Engine 21 05-26-2004 02:42 PM
