Holley 4777 Revisions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 04:57 AM
GMCBEAST's Avatar
Hey guys,
Does anyone know the differences in these Holley revisions? I have a 4777 that I am rebuilding and have no idea which model I have. The choke tower has been milled off so I can not read it from there and only wrote down 4777 in a parts journel I keep. I want to build it to the most up to date revision I can, including jet and orfice sizes. Couldn't find much on the net other than the original had 2 power valves. Thanks for any and all help.
Old 10-22-2011, 05:15 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
HOLLEY NUMERICAL LISTING HERE.
Old 10-22-2011, 05:22 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You may be able to tell from the metering blocks what "dash number" you have, although on my 4777-2 carb the blocks are not externally marked w/a p/n. There may be info on the web that will let you see what blocks you have by the PVCR and/or the IFR.
IIRC the 4777 carbs all had only a primary power valve, and the PDF would seem to confirm this- carbs on the list that have two PV's will use a footnote that denotes the secondary PV rating along w/possibly the primary PV rating. If you look down to the 4780/4780-1 carbs you will see what I'm referring to.
Good luck.
Old 10-22-2011, 05:27 AM
GMCBEAST's Avatar
Thanks Cobalt, very helpful. As far as parts go all the 4777's look basically the same from that list, metering block wise anyway. I wish Holley put out a spec sheet with orfice sizes on it. Very curious why original had 71 main jets then moved to 67's on first revision.
Old 10-22-2011, 05:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Possibly customer feedback that indicated it was pig-rich out of the box, especially if used on a dual plane intake?
Old 10-22-2011, 06:25 AM
GMCBEAST's Avatar
I have heard that the 4777's tend to run rich out of the box, is there any truth to that? I know carb's will act differently on different motors but there must be some guideline. Use to work at BG and know for a fact they sent those out on the rich side intentionally. Wonder if Holley does the same.
holley 4777-7 issues rb69 Engine 2 08-13-2010 05:27 PM
Quick fuel HR 650 or Holley 4777? Onsjos Engine 8 07-19-2010 04:53 AM
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 03:23 PM
Idle adjustment - holley 650 dp 4777 Toyman Engine 5 07-30-2005 08:07 PM
proform throttlebase upgrade,holley 4777 mrsir2u27 Engine 0 06-11-2003 09:39 AM
