Holley 5200 idles good but smog no.s are - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2009, 02:50 AM
Right now it's idling at around 1100-1200 rpm.I've gotten the air-fuel screw down to where a vac. gauge needle stays very still,but i get a reading of HC 184ppm .I also got 1.57% for CO. NO ppm was 103,according to a smog machine.It does have a good cat.The idle screw is backed out all the way.What else can i do to lower the rpm's? The engine is a 22r in a 86 toyota truck.The engine has the 5200,header,Jacobs,no smog equipment hooked up.Can i also lower the fuel level to see if that helps,or do i need to drill those tiny holes on the throttle blades?
Old 12-25-2009, 04:02 AM
sqzbox's Avatar
My pipes are my music
Can you back down the initial timing at all?
Old 12-25-2009, 11:25 AM
It's at 0* right now.If i backed it down more,wouldn't i lose power and mileage? Can i lower the float also to lower it?
Old 12-25-2009, 12:23 PM
sqzbox's Avatar
you could and it might help only if the float is set too high at the present.
Have you double checked for vacuum leaks? A big one like the size of the PVC valve could raise your idle speed and, adj. the air fuel ratio would have no effect. Same goes with the idle speed screw, you could back it all the way out and still not get the rpm down enough.
Another thing to look at is down the carb. Look and see if the throttle blades are all the way closed or open just a fraction. If they aren't, something is causing them to not to close all the way and that would take the carb. off the idle circuit.
Just some Idea's to look at. Hope it helps.
Old 12-25-2009, 02:56 PM
I looked at the carb a lot closer and i noticed it has a secondary screw just like the secondaries on Holleys.I'll try turning that down.I'm almost sure that's going to be it! Thanks.
Old 12-25-2009, 03:00 PM
sqzbox's Avatar
Good liuck! hope it works for you! Have a merry christmas too!
Holley 800cfm spread bore-any good for street/strip? ratlover Engine 14 06-21-2015 01:40 AM
New Holley carbs any good? (4160, Street Avenger,etc) Saito Engine 1 08-11-2008 06:25 PM
Is the Holley commander 950 Pro-jection a good set-up?? hemi43 Engine 3 08-01-2006 06:17 PM
3.8 olds engine idles good but stumbles when revved fumplet Engine 4 07-25-2006 01:51 PM
Holley carb paint, any good ? Vortech 4.3 Engine 3 03-11-2006 08:27 AM
