Holley 570 cfm electric choke
I just put on a holley street avenger 570cfm carburator on my 69 camaro. It has a 307 small block in it. My question regards the electric choke. Is it normal to have to let it run for 3 or 4 minutes and then romp the daylights out of it to get the idle to go down? It idels around 1800 rpm for a couple of minutes before it will settle down after i romp it. If this is normal i hate electric chokes! Thanks
No, it should take only a slight 1/4 movement of the gas pedal to make the idle back to normal once the choke backs off. Like everything else, electric chokes are fine when adjusted correctly. |
Thanks for the quick replies guys! So it sounds like it is normal for the choke to take a little bit, but i need to back down the choke idle screw a bit?
| 1980 TA choke relay | jdcoic | Electrical | 17 | 05-16-2013 07:09 PM |
| Holley 6425 650 CFM 2 barrel | lluciano77 | Engine | 15 | 01-28-2011 11:26 AM |
| electric choke | Yub350 | Electrical | 4 | 11-29-2004 03:12 PM |
| Electric Choke Conversion ? | bigjoedo | Engine | 2 | 01-27-2003 07:17 PM |
| 600 cfm holley vs 750 cfm holley | 85 regal | Engine | 7 | 11-27-2002 06:25 PM |
