Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HOLLEY 600 4160 CARB QUESTIONS?
Old 05-22-2003, 02:23 PM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
I think he's talking about some of the Holleys have a check valve on top of the front fuel bowl. If I remember the valve is actuated by a lever that is in contact with the driver's side linkage. It is slightly open when you're at idle and closes when you go off idle. I don't know exactly what it's supposed to do. I had a carb rebuilt by a local speed shop and they essentially eliminated it and plugged the hole.
