Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HOLLEY 600 4160 CARB QUESTIONS?
Old 05-22-2003, 02:57 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
I suggest that you go to Hollys site and read up on your carb. Also the Knowledge Base has a lot of info.If it's spitting gas it could be the float level, blowen power valve, to much gas pump pressure,sticking float, or crud in the needle jet.
<a href="" target="_blank"></a> OR
[ May 22, 2003: Message edited by: 1BAD80 ]</p>
Luv the smell of NITRO in the morning.
