Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley 600 carb specs for my weiand 671 . HELP !!!
Old 10-10-2010, 03:10 PM
mustang 671's Avatar
mustang 671 mustang 671 is offline
hi all. have been working on my car all day. dumped the old fuel and cleared the lines and re filled with 99 pump gas . i have 2x vac secs 600 holleys on 671 weiand on 351w. this is what i have
-secondary springs are colour purple
-i have prefix 70 jets in both primary metering blocks and 1 of the sec metering blocks as the other cannot be fitted due to no room
-power valves have prefix 65
-acc pump cam is colour orange ( i think, as i havent seen the shade of brown) not sure which position it is in.
-diapghram on the acc pump is colour green ( not sure if they have different ones ?)
so my question is are there any changes that i need to do that are obvious at this stage ? i need to order some bits from holley this week so can always order some other bits from the reccomendations from you all. i have previously set out my engine specs in a previos post (671 weiand blower 351w engine) i have a high lift crane cam. 7.48.1 cr. blower underdriven 13% so hoping for around 6-8 psi to begin with.
i have set my inital timing at 12d btdc and total at 28d btdc all in at 3000rpm.
does this sound about right to get it started and running so i can run in my cam. its a fresh engine and only has had 5 min or running time so far.
had timing issues previous which i hopefully have got better to start with. i have a omex ecu that is open to be played with . so i can put in what figures i want,
it starts at 450 rpm on the bottom scale and the side scale going up is engine load from 1% to 99% . the rpm goes up by around 400 rpm for each incrament.
i.e
99
89
79
69
59
49 i can put any degree figure in this table
39
29
19
09
01
450-850-1200-1600-2000-2400-2800-3200-3600-4000-4400-4800-5200
what do you think as a start before i go to the dyno so i can run it in for 500 miles
thanks guys
