Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 600 cfm vacuum secondaries, electric choke (0-80457S)
Old 10-06-2012, 11:55 AM
eric32 eric32 is online now
If your talking about that inside lever with the hole in it that is for a ford kickdown cable I believe and unless your using your carburetor on a for automatic that uses a kickdown cable you wont be using it. Hope that helps.
eric
