-   -   Holley 600 cfm vacuum secondaries, electric choke (0-80457S) (http://www.hotrodders.com/forum/holley-600-cfm-vacuum-secondaries-electric-choke-0-80457s-224711.html)
ggevaert 10-06-2012 08:56 AM
1 Attachment(s)
Hi,
Can someone explain what the part on the inside of the throttle assembly is for and whether there is a spring missing on mine. I could not find anything specific on that area online.
Please see attached pic of my holley.
Thank You :welcome:
eric32 10-06-2012 11:55 AM
If your talking about that inside lever with the hole in it that is for a ford kickdown cable I believe and unless your using your carburetor on a for automatic that uses a kickdown cable you wont be using it. Hope that helps.
eric
ggevaert 10-06-2012 11:34 PM
ford kickdown
Hi Eric32,
Thanks, that helps a lot. My truck is a GMC (1984) so I will not be using it.
Cheers. :thumbup:
