Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 6425 650 CFM 2 barrel
Old 07-29-2003, 04:34 PM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
650 2bl Carb
The 650 2bl carburetor having the large venturi will not have the same type of drivability as a small 4bl carburetor would. Your engine is an air pump, so it will flow the same amount of air at any given point (unless it's restricted) using a smaller 4bl carburetor will increase the air velocity at lower RPM and engine load giving you better idle quality, throttle response, and drivability.
