Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 6425 650 CFM 2 barrel
Old 07-30-2003, 08:02 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
If you ran a 650 Vacuum Secondary 4bl carburetor it will give you better acceleration and drivability than the 650 2bl since the air will be moving at a higher velocity. This will give you better atomization of the fuel.
