Holley 650 double pumper - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2010, 08:00 AM
Hi,I have just bought a holley 650dp off ebay,have noticed that looking at it as if it was on the motor the throttle linkage and fuel in pipes are on the left hand side,and the choke tower is at the back towards the firewall!does this mean the baseplate has been rotated,does this work ok if it has been,all my other holleys have had the throttle linkage on the right hand side looking at the engine,thanks for any info ??
dave
Old 10-10-2010, 09:28 AM
BOBCRMAN@aol.com's Avatar
Bowls have been installed wrong. Front is on the rear etc. Or base plate is installed backwards
All Holley carbs have throttle linkage on left side of carb. Choke housing/plate in front..
Old 10-10-2010, 10:23 AM
If the baseplate has been rotated 180 degrees will the carb still run ok,I presume they did this to allow for the linkage to work on their application?
Thanks in advance
Holley 650 DP vs. Edelbrock 750 4speed57 Engine 5 05-03-2009 12:52 PM
Holley Double Pumper Question... Blazin72 Engine 9 01-07-2006 01:50 PM
Holley 650 / Edelbrock performer combo Andy in SD Engine 4 11-07-2005 10:25 AM
Holley 950 Double Pumper Corb rayfox Engine 2 04-19-2004 08:45 PM
Double Pumper vs. Vac Secondaries 78 monte Engine 10 03-04-2003 02:32 PM
