Holley 650 DP - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2011, 04:44 AM
67Mustang Al.'s Avatar
Holley 650 DP
Just wondering if someone has some info/links on Holley jet bore sizes. I have what i think is a 67 main jet from the primary side of this new stock standard Holley. From some data i found on the web the inside or bore size of the 67 should be .068" but when i tried to check the size of the 67 using a .068 " gauge drill it was far too large to go through the jet . It may be around .064 or .065".
My question is are there different series of jets for cruisng and racing as the series i found on the net are 122-67, diameter .068" .from "Ken's Speed Machine"
The way this 347 starts from cold with choke needed for about 4to 5 minutes and the odd crackle/backfire looks like its on the lean side of normal with 12 degrees of initial timing.
Cheers from downunda
Al.
Old 06-24-2011, 11:49 AM
lg1969's Avatar
Google "Tunnel Ram 406"
http://tgsperformance.com/holley.htm
Old 06-24-2011, 05:58 PM
Thanks for the link. Yes the 650 i have is correctly jetted according to the mumbers stamped on the jet. I found some comment that Holley jets need pin sizing as they are all over the place from new. So that would explain why the 67 jet i have is not .068 in bore size. To make it standard i will pin drill it and try it again before i change for a richer jet.
Cheers
Al.
Old 06-25-2011, 02:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Cheers
Al.
The number actually represents what the jet flows- not necessarily the diameter of the hole in the jet, although they can be close to one another.
You may even find that a jet could flow less after being drilled out- something to consider when you go to modifying jet sizes. The length of the orifice along w/the inlet and outlet chamfer angles and finish are very important to what a jet flows, as well.
Old 06-25-2011, 06:10 PM
HI 327
Yes that makes sense as some jets are relieved or tapered into the final bore size i think for increasing flow rate for whatever application.
The 67 jet should have a diameter of .068" according to Holley and the ones i have which are new are around .064,.065" so i am going to drill them out to .068 and see what happens. I have bought a 1/4 32tpi die so i will use my small lathe and turn up some spares and play around with size and shape. I have an air'fuel ratio meter so some guess work will be eliminated.
Al
Holley 650dp holley 750dp dave350v8 Engine 4 10-12-2010 09:45 AM
removing old holley gasket material & couple other holley questions darkostoj Engine 6 06-30-2009 07:06 AM
Holley 750 dickeymoore Hotrodding Basics 2 04-28-2007 08:32 PM
Q jet VS Holley?? Trav Engine 37 03-06-2007 06:11 PM
Holley 94 stromberg 97 Holley 94 BruiseAndy Engine 1 03-28-2003 03:12 AM
