Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 650 DP Mec Sec or 750 Vac Sec
Old 12-28-2003, 09:36 PM
DTL504 DTL504 is offline
84 Z28 Convertible
Cam: Grind: Solid Lunati/ (Recommended by Harold Brookshire)
280/284F10 .525/.530 Lift, 247/251@.050, 159/162 at .200, .560/.565 valve lift(1.6), Pro-Street power with an extra 5* at .200" 2500-7000 RPM Range, Advance Cam 4* Degrees as Per Harold, .026" Valve Lash Hot, Adjustment Range: .018" to .030" Hot. The SB280/284F10 has 62° of overlap. The valve timing is: IVO 33° BTDC IVC 67° ABDC EVO 75° BBDC EVC 29° ATDC. The int CL is 106° ATDC.
