I would run the 750 vac. for now. The 650 DP is too small for your combo. That is a bigger cube motor with a cam that is good sized. I would go with a 750 DP or a 750 vac. sec.. If you want better performance use the DP. If you want better mileage and streetability use the vacuum carb.
