Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 650 HP flow numbers
Old 11-19-2012, 10:12 AM
painted jester's Avatar
painted jester painted jester is offline
Last journal entry: 383 BLAH, BLAH.
Your engine needs X amount of airflow to reach a certain power level efficiently. The formula for CFM consumed is (CFM = CID x RPM x VE ÷ 3456). Here CID = Cubic Inches; & VE = Volumetric Efficiency. This is just a rough estimate as VE number is the basic efficiency or cylinder filling of the engine. Let's take a typical small block chevy 383ci stroker engine at 6500 rpm assuming 100% VE. Plug in the numbers & you get a CFM requirement of 720. Street motors might be 90% & a good race engine might be 125% with a single carb! But put on a tunnel ram or a high rise race intake and cfm climbs drasticly because of the velocity of the ram effect aiding the engines ability to flow more air !! throwing that formula out the window
I thought this might help
Jester
