Holley 650 HP flow numbers - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-19-2012, 07:41 PM
Richiehd's Avatar
JS-70
As always, thanks for the input. I may step up to a 750. Tunnel ram is out, if you knew the type of skiff you would see why. Besides it wouldn't fit under the hood!!
  #17 (permalink)
Old 11-19-2012, 07:46 PM
F-BIRD'88's Avatar
Yada Yada Yada
You can up grade your 650 holley to a 750HP using the Holley or Proform
HP 750 carb body kit. It works very well and is well worth it.
Fraction of the cost of a new carb. All the gain.
  #18 (permalink)
Old 11-19-2012, 07:50 PM
F-BIRD'88's Avatar
Yada Yada Yada
You need significant engine horsepower increases to see a gain in boat speed , on the water.
The tunnel ram works very well on boats and will make the most power on your motor.
But do not make the mistake of choking it with tiny carbs. Use two 650's or two 750's
on it. Two 750 edelbrocks would be cool.
  #19 (permalink)
Old 11-19-2012, 08:03 PM
painted jester's Avatar
Last journal entry: 383 BLAH, BLAH.
A cross ram would fit under the hood!
Jester
  #20 (permalink)
Old 11-20-2012, 12:14 AM
gearheadslife's Avatar
MentalMuffinMan
Originally Posted by ap72 View Post
properly built and tuned a bigger carb will NEVER cause a loss of power in the mid range or even off idle.
That old wives tale comes from people who can't build and tune carbs.
thats just silly.. if that had any truth to it, all the carb based engines at engine masters would have the biggest honk'n dominator on top..
they don't
  #21 (permalink)
Old 11-20-2012, 12:21 AM
MentalMuffinMan
they don't
  #22 (permalink)
Old 11-20-2012, 12:49 AM
Thats not silly its true you might not gain any horsepower from the bigger carb unless you needed more carb in the first place but tuned and built right you will not lose any either one reasons why they dont all have bigger carbs is cost have you prices one them big honkin dominator lately and whos going pay all that money if you not gaining a lot of hp not me
  #23 (permalink)
Old 11-20-2012, 03:08 AM
MentalMuffinMan
sorry signal strenth goes out the window.. if you want only peak hp..
then I'd guess it might be right..
some like having a powerplant that doesn't cough and fart untill 2500rpm+
and those pro's at engine masters the cost of a dominator is peanuts..
  #24 (permalink)
Old 11-20-2012, 07:34 AM
How fast is fast enough?
The signal strength is more than adequate if you know what you're doing- again most people just don't know what they're doing.
As for Engine Masters- the carbs are restricted by the rules.
  #25 (permalink)
Old 11-20-2012, 11:36 AM
ap72: Your handeling this great LOL
Im going to set back and read this argument
  #26 (permalink)
Old 11-20-2012, 11:44 AM
MentalMuffinMan
man you could save hollley a ton of money.. look at all the parts they'd not have to stock or make.. warehouse if they could just cast a dominator and make it work for everything..
guess holley doesn't know either.. you should go pitch your thoughts to them.. at it save them a ton of dough..
  #27 (permalink)
Old 11-20-2012, 01:07 PM
That would actually lose holley a ton of money... And that's where professional carb shops come into play, fixing holley's short comings.
  #28 (permalink)
Old 11-20-2012, 01:50 PM
vinniekq2's Avatar
gearhead,Im not here to defend AP72,just curious what you think is the correct size carb for My1.3 litre 13b with a mild bridge port?
The Following User Says Thank You to vinniekq2 For This Useful Post:
painted jester (11-20-2012)
Holley 650 DP 67Mustang Al. Engine 4 06-25-2011 06:10 PM
holley 650.. 87monte385 Engine 20 08-22-2010 02:23 PM
650 Holley Double Pumper or Edy 650 Thundre Series topdogger Engine 24 08-01-2007 08:12 AM
flow numbers.. bonzipenguins Engine 17 01-30-2007 12:38 PM
Holley flow numbers lluciano77 Engine 0 09-14-2004 05:12 PM
