Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - holley 650dp for my 355
  #40 (permalink)
Old 03-26-2013, 03:51 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
The reason your secondary did not open all the way is that is all the motor wants. Secondary will only open what the motor needs. If you use a 780 CFM carb and the motor can only pull 700 CFM, the secondary will only open so much.
BTW: I do not have check ball in dual quad vacuum secondary Holley tunnel ram setup and does not bog at all. The tires spin so fast it practically put a hole on the black top, and it has 15" of vacuum at idle.
