holley 650dp for my 355 - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-26-2013, 04:31 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Remove the check ball in the housing. It will make a big difference. Use the paper clip method to see if the secondary is opening.
  #32 (permalink)
Old 03-26-2013, 04:47 PM
spinn's Avatar
I built my racing 440 about 20 years ago.
I haven't had time to go to a track in 10+ years.
There is no track for me in 250 miles in any direction.
It would have to be a family thing, and my girlfriend is a big city person who hates cars.
You would remove the checkball on only low vacuum engines or all?
  #33 (permalink)
Old 03-26-2013, 04:51 PM
lg1969's Avatar
The reason your secondary did not open all the way is that is all the motor wants. Secondary will only open what the motor needs. If you use a 780 CFM carb and the motor can only pull 700 CFM, the secondary will only open so much.
BTW: I do not have check ball in dual quad vacuum secondary Holley tunnel ram setup and does not bog at all. The tires spin so fast it practically put a hole on the black top, and it has 15" of vacuum at idle.
  #34 (permalink)
Old 03-26-2013, 05:09 PM
spinn's Avatar
A hole in the blacktop...really?
My grand coupe clocked a 13.0 flat back in about 92.
440, .509 cam, single plane,727 hi stall, 4.10 gear, hoosier DOT. It was a lot of fun. I followed the reciepe on the box. The jobber connection parts had formulas on the back for bracket racing. So I built the 13 second car, and it ran 13 seconds . Go figure.
  #35 (permalink)
Old 03-27-2013, 02:43 PM
prettyboyced's Avatar
Do I change to springs to limit mech advance or weights
  #36 (permalink)
Old 03-27-2013, 03:02 PM
lg1969's Avatar
How much manifold vacuum are you running at idle? The cam looks pretty big. What is the cam specs if you know?
  #37 (permalink)
Old 03-27-2013, 03:08 PM
To b honest I have no Idea do I plug a vacuum gauge to the carb??? All I kno it's a enough to keep vacuum brakes and power steering
  #38 (permalink)
Old 03-27-2013, 03:11 PM
lg1969's Avatar
Just enough. Sounds to me you are running under 10" at idle and 7" in gear.
  #39 (permalink)
Old 03-27-2013, 04:36 PM
  #40 (permalink)
Old 03-27-2013, 04:40 PM
spinn's Avatar
Originally Posted by F-BIRD'88 View Post
vac secondaries do not work on manifold vacuum at all.
Okay that is the second person to say this.
If you drill a big hole in the manifold, your carbs secondary, or the carb for that matter is not going to pull fuel. So manifold vacuum is the signal that makes the carb function. Or the negative pressure underneath the carb to simplify it even more.
I think you are having a problem because of a comment I made about my engine. That I had described the idle with a unit of vacuum and where I measured this.
I have worked with carbs for years of all types. To say that it would have opened all the way racing, and NOT stumbled at cruise, is a bold statement.
The port for the pod is at the venturi. Of coarse , that is the best place to get a signal for the pod.
To say that the vacuum underneath the carb don't have anything to do with operation, now said twice, is not believeable.
  #41 (permalink)
Old 03-27-2013, 04:58 PM
lg1969's Avatar
What happen to the manifold vacuum when you floor the gas pedal. It drops to zero or close to it.
  #42 (permalink)
Old 03-27-2013, 05:08 PM
spinn's Avatar
It goes to 9 lbs of boost.
LG, Are you going to explain your comment?
A venturi does not generate vacuum. It pulls a fluid.
A nozzle on a garden hose , when you open it. The water pressure comes from the faucet not the spray nozzle.
  #43 (permalink)
Old 03-27-2013, 05:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Neither. If you have a GM hei, info on limiting the mechanical advance, as well as timing info in general, is here.
To check the vacuum, connect a vacuum gauge to a FULL TIME vacuum source, also called "manifold" vacuum. A manifold vacuum source can be located on the carb (on the baseplate of a Holley), OR from a port located on the runner of the intake manifold.
The 'other' type of vacuum signal is called "ported" vacuum. Ported vacuum is absent (or nearly so, depending on how far the primary throttle blades are opened to set the idle speed) w/the throttle blades closed because of where the vacuum orifice is located in the carb (above the throttle plates), and will only be present when the throttle blades are opened to some degree. On a Holley, ported vacuum port is the one located on the metering block.
  #44 (permalink)
Old 03-27-2013, 05:17 PM
lg1969's Avatar
I'm gone.....Goodby
  #45 (permalink)
Old 03-27-2013, 05:23 PM
spinn's Avatar
Look in my journal I run a roots blower.
What?
Please explain the secondary not needing vacuum. I feel like im not hearing something, but your quotes speak for themselves.
Holley 650dp too much for engine? bad street carb? IntrstlarOvrdrve Engine 8 11-02-2010 11:16 PM
Holley 650dp holley 750dp dave350v8 Engine 4 10-12-2010 10:45 AM
Adjusting 650 Holley on 355 Bonger6 Engine 3 07-12-2010 08:58 AM
Holley 4150 650dp specs chevythmpr Engine 1 11-29-2009 02:58 PM
Holley 4150 355 won't stay idling! fastrehotrods Engine 6 05-27-2006 08:45 PM
