Sorry for the newb questions, I am fairly new to the game and I keep running into problems. Anyway, I have a holley 650 double pumper that I am having hesitation issues with, it is fine idling around and doesn't stumble when I ease into the throttle but as soon as I go more than half throttle it will bog down then come alive. My dad thinks that it is too much carb for the engine and wants me to put a holley 600 on it with vac secondaries as he says it will be better for the street. I still think it might be another problem such as the power valve, but I don't know how to check if that is the problem or see what I need to do. Here is my set up: 388 with comp cams xe274h, holley dominator intake, dart sportsman II heads and accel ignition with 14 degrees BTDC timing. The plugs are not fouling out but I have also noticed that after heavy acceleration when I let off it smokes like its running rich for a moment. What could be causing this hesitation? Thanks!
Mine has excellent mech street manners, burn rubber on the fly. Changing carbs is not the answer. Rebuild what you have, it's easy and 40 bucks. I had the same problem, turned out to be a clogged fuel sock collapsing. Check your float levels, be sure you have enough fuel in the both bowls and your are not running out of fuel. Don't overlook any restrictions in the fuel delivery, particuly under load. You can do very little on the driveway. That carb requires a fair amount of gas. Squirt up to a 31's, dump the 28's. Set your idles mixtures to about 1 or more turns out. Check vacumn at idle, besure your choke is not engaging, check fuel pressure under load, vacumn can be 10+ at idle with cam, 6.5 power valve will be fine IF OPENING. It has to be delivery. (Is it mech or vac?) Replace rear tires after a few runs.
A bog is to large of a delivery nozzle, so go the a smaller nozzle like turbolover recommended.
A backfire thru the carb is to small of a nozzle.
You can also do a Search This Site to find all the other posting on the same issue, or on the bottom of the page on your posting which gives a few of them.
I would advise to get a tuning kit for your carb which as the different cam's & nozzles.
I like using the pink one for a steady long shot.
A bad power valve cause's flooding.
Here is a test to check the power valve if it's bad,
If you expect a blown power valve, use this simple test.
TEST: At idle turn your idle mixture screws
(found on the side of the metering block) all the way in.
If your engine dies the power valve is not blown.
It is a 79 el camino, 3.73 gears auto trans with 2500 stall. Oh also vac advance is not hooked up, with it hooked up the car won't idle below 1500 without dieing in gear.
Tee off at the fuel inlet at the carb, run a line back to the firewall and up past the lip of the hood. Mount a 0-15 fuel pressure gauge on the cowl with duct tape or tie wraps or whatever you have to use so you can see the pressure gauge through the windshield while you are driving. It's only temporary, just until you get the pressure under control, then you can remove it. This is the only way you will know what the fuel pressure going into the carb is while you're driving. Holleys will tolerate a maximum of 6 1/2 lbs of fuel pressure before the pressure overpowers the needle and seat and blows raw fuel into the intake manifold, so get the pressure under control, like 6 psi. Some guys will say that they are running a mechanical pump that says it is compatible with the carb. BULL HOCKEY. I have seen stock-type mechanical pumps that put out 10 psi.
Many of you youngsters have grown up with electronic fuel injection, where more pressure is more horsepower. It's not like that with a carburetor. More pressure than 6 psi on a Holley blows fuel past the needle and seat and loads the motor up with raw fuel. Engineer for 5 psi on an Edelbrock, Carter AFB or Quadrajet. They are more sensitive than a Holley.
Okay- does the carb have 4 equal size barrels or are the front ones a lot smaller than the back ones... like on a Q-Jet carb? Holley made a 650 DP mechanical seondaries. It was Q-Jet replacement carb model 6210.
is the intake a street dominator ( which is a dual plane intake) or strip dominator ( a single plane intake ) if it is a strip dominator , you need more fuel ! have someone follow you when you go for a test drive and tell them too watch if they see black smoke come out your pipes when you acellerate , black smoke is too rich, you'll have to lean your carb out through the acellerator pump cams and jets, but if there is no black smoke she is running too lean on acelleration,go to a 50 cc rear acellerator pump (Holley 50 cc pump part #20-11 ) ( Holley trick kit part # 37-910 ) and change your front and rear acellerator pump cams, and go to a bigger acellerator discharge nozzle . 6.5 power valve should be ok for your set up.to be sure check your manifold vacuum , i think there should be a chart to go by for power valves. tune your car like F bird88 said, ( do your timing and recurve first then do your carb) more base timing and a dist recurve , and adjust front and rear throttle plates. what kind of exhaust are you running on your car, you need a free flowing exhaust to go with your set up
Related Threads
Hot Rod Forum
2.2M posts
175.5K members
Since 2001
