Holley 750 on a 454, what jet size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 10:38 AM
JamesRS's Avatar
Hi all, I have a question about where I should start on jet sizes for my Holley 750? I'm getting ready to rebuild this double pump carb (mechanical secondaries) that came off of a SBC. My BBC will probably need different jets, so I figure while I have it open I can put in jets that are around where I will need to start.
My combo:
454 .040 over = 462 ci
Stock 049 casting oval port heads
10.2:1 compression Hyper-eutectic pistons
Comp Cams XE268H - 268/280 duration (224/230 @ 050) 515/520 I/E lift
Weiand 8013 dual plane manifold (Idle - 6500)
Proform HEI
1.7:1 Stamped steel rockers
Any suggestions would be appreciated.
Old 02-18-2005, 10:48 AM
Just a guess to get you in the ballpark, 78 front and 84 rear.
Old 02-18-2005, 10:52 AM
4 Jaw Chuck's Avatar
Stock Holley jet sizing on Mortec.com.
— Han Solo
Old 02-18-2005, 05:01 PM
JamesRS's Avatar
Thanks guys, this gives me an idea where to start.
Old 02-18-2005, 08:34 PM
lluciano77's Avatar
Start with the stock jets. Drive at various speeds from 10 mph to 60. See if there is any lean surging. If so jet up. IF not you are probably on the money.
Q jet VS Holley?? Trav Engine 37 03-06-2007 07:11 PM
Holley 750 vac sec Carb onecoomofo Engine 6 05-02-2004 05:54 PM
Holley 650 DP Mec Sec or 750 Vac Sec DTL504 Engine 7 12-29-2003 05:25 PM
jet size comparing Jared Engine 1 12-25-2003 05:55 AM
600 cfm holley vs 750 cfm holley 85 regal Engine 7 11-27-2002 07:25 PM
