Holley 750 double pumper - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2013, 07:03 AM
I installed a brand new Holley 750 on my sbc350. Idle was a little high. I messed with the electric choke and that helped a lot. I messed with the idle screw and did almost nothing. Then I realized that my throttle although it looks like it is returned all the way , it is not. If i put a little pressure on it idles great. So i picked up a throttle return spring. The spring is pretty taught, but it is still not enough pressure on the throttle to correct idle. I noticed that the throttle is effected by the pump spring adjustment. being that I only needed a very small amount of adjustment I eased up the lock nut on the little red spring so that the throttle would drop down 1/16 " or so and solve the problem. It did not. Now what?
Old 06-29-2013, 09:13 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Are the throttle plates centered in the bores? Sometimes they bind, not closing all the way. If that's not the problem is the throttle adjustment screw hung up on the high idle cam?
Semper Fi
Tuning Holley 750 Double Pumper Rod Breaker Engine 11 04-28-2013 08:58 PM
750 double pumper dewdrinker Engine 1 01-05-2011 08:46 PM
750 double pumper dewdrinker Engine 4 01-02-2011 04:51 PM
Carb Rebuild Question (Holley 750 double pumper, mech. Sec.) Zeeb Engine 0 10-30-2010 10:45 AM
750 double pumper help!! matts94sc Engine 4 12-22-2006 09:48 AM
