Holley 750 throttle return spring.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2003, 07:16 PM
Trav's Avatar
Luv the smell of burnt RICE
i noticed from swiching from my holley to my Q jet that the throttle was realy stiff on the holley.. its just a plain old 750 with secondarys.. i baught the adapter kit for the throttle plate and springs.. but dam with both springs on the throttle is as hard to push as the clutch.. wuts up with that?? is this just my carb?? i removed one spring.. just a little softer.. nothin major.. but then when o let off the throttle it idles high.. the throttle isnt closing all the way.. this carb is fairly new... any ideas???
Old 09-24-2003, 07:26 PM
jrhoss's Avatar
make sure the throttle linkage is in the topmost hole in the lever, that will give you a stiff pedal if it is too close to the shaft. it sounds like you pulled the linkage to fit on the carb its probly hangin up
