holley 800 spreadbore on 350 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 09:51 PM
ROCKETWAGON's Avatar
if you got it...SPRAY IT
can anyone tell me what jet and power valve sizes i should start with
Old 08-09-2012, 11:25 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Not without some motor specs. That's a lot of carb for a 350.
Semper Fi
Old 08-10-2012, 12:08 AM
vinniekq2's Avatar
Ive used 850s on a 355 sbc.You need to tune it,great carb if you have one. I wouldnt look for one if I was buying a carb
Old 08-10-2012, 07:08 AM
350,good heads(p&p),eldebrock intake(performer),lunati cam(292-480)have a q-jet on it but not satisfied. i have a 600 holley(4160) and the 800 spreadbore. the 800 brought the 383 it was on to LIFE
Old 08-10-2012, 12:06 PM
vinniekq2's Avatar
I would prefer you use a 4777 to wake your car up.The 800 will need more tuning because it has huge secondaries for a 350.You have a very mild cam. The performer manifold will help you as long as you do not use a spacer.keep it a 2 plane intake. Bolt it on the way it is.Of course check the jets and PV first so you can have different parts on hand for changing.
does that carb have a pressed in booster venturi?Dyno time is expensive but a worth while investment
Old 08-10-2012, 04:44 PM
Is it a vacuum or mechanical secondary?
Old 08-10-2012, 08:21 PM
mechanical.
thanks for the advice.
Holley spreadbore + edelbrock squarebore intake q's Bad66 Engine 7 04-29-2011 04:47 PM
Holley Spreadbore godsMistake Engine 3 11-07-2007 01:02 AM
Anyone need an 800 Holley? pickler91 Engine 1 12-02-2006 10:45 PM
What Jets for Holley 800? camarochas Engine 2 08-03-2006 11:21 AM
800# for holley Hot_Rod_Faith Engine 2 07-19-2004 02:09 PM
