Holley 850 DP on auto - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2011, 01:57 PM
Jason7504's Avatar
I found a good deal on a rebuilt Holley 850cfm Double pumper for $200. I have a 580-600hp 468 but i'm using the stock auto and rear for now. I do plan on getting a 4L80 trans with 3000 stall hopefully by summer but will still use the 3.08 posi rear for a little. I know you can run DP's with manuals or auto's with high stall converters and low gears. Do you think the DP would be ok when i get the 4L80 with 3000 stall but still use my 3.08 rear for a little?
Old 01-17-2011, 02:40 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i think it would be ok
but there are some other guys here that know more than i do on carb. choices
Old 01-17-2011, 03:43 PM
ericnova72's Avatar
More for Less Racer
It will be fine, size is right up your alley for the engine and hp requirements. How it acts with 3.08 gears just comes down to your right foot.
Old 01-17-2011, 04:00 PM
Jason7504's Avatar
i heard that they can bog more with an auto especially with a low stall and high gears..
Old 01-17-2011, 04:10 PM
BOBCRMAN@aol.com's Avatar
In real life. An 850 dp. Used on a vehicle with stock type rear and a stock to near stock convertor. Will be a gas guzzling, cylinder wasking, oil diluting, plug fouling, TURD. You will be much better with a 750 vac. secondary carb.
Keep the carb on the shelf until the trans and rear mods are performed..
Old 01-17-2011, 05:02 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Definitly not to much carb for you engine though.
Cole
Holley 650dp holley 750dp dave350v8 Engine 4 10-12-2010 09:45 AM
Auto Tech vs. Auto Body Career? mgold Hotrodders' Lounge 41 01-04-2010 07:36 AM
removing old holley gasket material & couple other holley questions darkostoj Engine 6 06-30-2009 07:06 AM
Manual Holley carb on auto car sleepr Hotrodding Basics 1 08-11-2005 09:01 PM
Holley 94 stromberg 97 Holley 94 BruiseAndy Engine 1 03-28-2003 03:12 AM
