Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Holley 850 DP Question
Old 06-06-2012, 01:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 396chevelle
In a nut shell my 496 was tuned on the dyno before it was put in the car. Now that it's in the car it has ran great, but the only issue I'm having is that when idling the exaust will burn your freaking eyes out. Any recommendations? I did want to see what size power valves were in it after I checked my vacuum. I have 6" of vacuum in drive at idle and the carb has a #4 power valve in the primary metering block and a plug in the secondary metering block would you guys recommend droping to a #3 or is the #4 close enough? Primary jets 78-78 and secondary jets 86-86. Carb is set to highest vac seems to run great, but the exaust at idle will make you cry!
The eye watering exhaust is unburned hydrocarbons, caused by the EGR effect of the cam timing. This is common w/a cam that has a lot of overlap/tight LSA/late closing intake.
If you can, add initial timing. Just be sure to balance the total timing by removing timing from the mechanical advance so the total timing doesn't go too high.
In some cases, dialing in some vacuum advance could help. But having the vacuum at idle that low will make that impractical, though. I'd advise you to use vacuum advance, but in your case use ported vacuum for the vacuum advance. Limit the vacuum advance to 10 degrees.
