Holley 850 DP Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2012, 09:27 PM
396chevelle's Avatar
In a nut shell my 496 was tuned on the dyno before it was put in the car. Now that it's in the car it has ran great, but the only issue I'm having is that when idling the exaust will burn your freaking eyes out. Any recommendations? I did want to see what size power valves were in it after I checked my vacuum. I have 6" of vacuum in drive at idle and the carb has a #4 power valve in the primary metering block and a plug in the secondary metering block would you guys recommend droping to a #3 or is the #4 close enough? Primary jets 78-78 and secondary jets 86-86. Carb is set to highest vac seems to run great, but the exaust at idle will make you cry!
Old 06-06-2012, 02:54 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The eye watering exhaust is unburned hydrocarbons, caused by the EGR effect of the cam timing. This is common w/a cam that has a lot of overlap/tight LSA/late closing intake.
If you can, add initial timing. Just be sure to balance the total timing by removing timing from the mechanical advance so the total timing doesn't go too high.
In some cases, dialing in some vacuum advance could help. But having the vacuum at idle that low will make that impractical, though. I'd advise you to use vacuum advance, but in your case use ported vacuum for the vacuum advance. Limit the vacuum advance to 10 degrees.
Old 06-06-2012, 08:55 AM
OK, Thanks for the input! I'll give it a shot.
Old 06-06-2012, 10:23 AM
Banned
Its very possible that your wot performance was tuned on the dyno with the jets rather than the pvcr's. A LOT of people do that and it is the WRONG way to tune WOT. You may need to step down a handful of jet sizes and open up your pvcr to get your cruise tuned right.
For idle you can adjust the idle feed and bleeds to get an acceptable idle and off idle transition.
Tuning a carb for peak power has very little to do with tuning a carb for peak performance. Peak power is easy, peak performance is much much harder.
Holley 850 DP running very rich flooding engine Schoust Engine 10 07-28-2011 05:54 PM
Holley 850 DP on auto Jason7504 Engine 5 01-17-2011 06:02 PM
Holley AED/Proform 850 eric866121 Engine 4 06-24-2009 11:31 AM
Holley 850 Carburetor defference JamesRS Engine 2 04-07-2007 01:03 AM
Holley 850 CFM Vacuum Secondaries.. PITA..!! Viet Nam Vette Engine 18 04-12-2006 08:54 PM
