Holley 850 DP running very rich flooding engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2011, 07:08 PM
Schoust's Avatar
Hey Guy's need some help with tuning a Holley 4150 with Mech. secondaries. The carb is on a 462 Pontiac with a Comp xe284h cam. The car has yet to be taken out on the road since it was dynoed. I'm thinking that the jet's might be the problem? I have checked the floats and they appear to be set properly. The car is stock with the exception of jet changes and a Proform base plate that I had to install because the stock base was cracked in shipping. LMK what you think.
Thanks
Old 07-27-2011, 07:35 PM
DoubleVision's Avatar
Usually this comes down to Needle stuck open due to trash in seat. Fuel pressure too high, Float level too high. Possible broken gasket in the carb itself such as power valve gasket. If it`s just running too rich then jet it down about 4 sizes. If it`s sure enough flooding then the issue is in one of the areas I pointed out.
Old 07-28-2011, 03:09 AM
Schoust's Avatar
Ymmv I'm thinking this might have something to do with the fact that my fuel pressure has been creeping upand down? I think its time to replace that regulater? Can the regulators be re built?
Old 07-28-2011, 12:02 PM
406 bug's Avatar
9.82 @ 139mph
Check pump linkage adjustment.
Old 07-28-2011, 12:30 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If it's running rich, barely idling, puking black smoke and symptoms of that nature pull the power valve(s) out and check to see if they are blown. Even if the carb has built in blowout protection check them out anyway.
Old 07-28-2011, 03:06 PM
Schoust's Avatar
Not sure what you mean about the linkage Bug? Are you refering to accelerator pump shot linkage? If so how does one check this? As far as the power valves go I did have some backfires while getting the distributor right. I thought that they were safe if you have blow out protection? The idle isn't that bad it's rough but I think that might be do to the 240/244 duration cam..... I will say that the engine is pig rich without a doubt! Can this be from the builder looking for big number's on the dyno thus installing more jetting than needed on the street? The engine was diagnosed with a different distributor with the timing locked out.....
Old 07-28-2011, 03:58 PM
Schoust's Avatar
Now were getting somwhere! Not sure what numbers are on the carb but it's a standerd double pumper with the choke horn (manual choke) The only mod that it has is a Proform base plate I had to change the original because it broke during shipping. The jet's that it made the most power with were 79's the timing was set at 37 degree's locked at 3000rpm...
Old 07-28-2011, 04:12 PM
406 bug's Avatar
9.82 @ 139mph
Before screwing with power valves, take time to determine what you engine needs. Its impossible to determine what opening you need in a PV without first reading your vacuum. Don't assume you need a certain PV based on your cam. Many have found that a valve opening at about half your vacuum reading at idle works quite well. e.g. vacuum reading 12-13 = PV of 6.5. Your current flooding could very well be a low vacuum condition that is causing the PV to open early.
Old 07-28-2011, 04:20 PM
Schoust's Avatar
When you say that it could be a Vac. problem are you saying that there might be a leak??I was hoping to find someone with a similar combo and work it out with them but I sure would like to learn how to come up with the proper combo too...
Thanks
Old 07-28-2011, 04:49 PM
406 bug's Avatar
9.82 @ 139mph
Thanks
No. Just that your current PV may not be right for your current setup.
Old 07-28-2011, 04:54 PM
Schoust's Avatar
Yea I realized what you were saying after I read it a second time. Idono,maybe my pump is causing this issue? It has been bouncing around for some reason? I run a Holey Black with matching holley regulator and as of late the pressure is moving around? I have to pull the filter and then check the regulator. I was kicking around changing the regulator to a return style,never did like the idea of dead heading the pump.....
holley running rich mainejohn Engine 35 04-10-2011 03:47 PM
engine running rich and popping from exhaust. novadan Engine 17 07-08-2010 09:23 PM
Holley Running Rich Silver00V6 Engine 11 12-12-2008 05:37 AM
Holley 600 flooding SLOW87CHEVY Engine 2 03-19-2007 01:49 AM
IS my Engine Running Rich? sum87mustang Engine 3 06-06-2004 08:38 PM
