Holley acting up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2008, 12:39 AM
Holley acting up
So i got this 650 double pump at an auction, rebuilt it and put it on my car. I set it up and it ran perfect but then i ran out of gas so i got some gas a few days later fired it up and it ran but no idle as if the idle circuts were plug, so i took it apart cleaned it and she ran again, but i ran out of gas. Again i got some gs a few days later went to fire it and the same thing runs but no idle, i pulled the set screw blew air through but still nothing. I'll clean it again tommorrow but why does this keep on happening!!? Thanks, Jake
Old 07-12-2008, 01:05 AM
327NUT's Avatar
Sorry but if I was a real smart a-- I could have a lot of fun with this. Does running out of gas all the time tell you anything about a DP Holley?? They are not very practical on the street, we used to call them "a semi-controlled leak". With the price of gas that would be the last carb I would be running. By the way, don't let your tank run dry, you're probably sucking up some debris off the bottom and depending on how good your fuel filter is it's most likely getting into your idle circuits.
Old 07-12-2008, 06:31 AM
It probably would not be a bad idea to umm put an inline filter in it ehh. Anything old thats been sitting i always run 2 inline filters (clear) one prior to the fuel pump and one after it.
Old 07-12-2008, 06:35 AM
dawg's Avatar
NAVY VETERAN
cmon now
DP carbs are as dependable as the person that tunes them.
never had an issue with a controlled leak.
your problem is crap in your fuel lines and tank.
Most likely rust particles.
quick fix is to drain tank and seal the tank with a tank sealer.
get it here:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
also use some metal wash:
Old 07-12-2008, 08:50 AM
The tanks been cleaned and i have a clear filter inline before the pump, the reason why i run out of gas is cause i run premium and i have to drive 40 miles to get it so i usually just fill a jerry can for the weekend. When running right i really like this carb performs, its much better than the 670 street avenger i had on it IMO.
Old 07-12-2008, 02:55 PM
cool rockin daddy's Avatar
Fill the tank up!!!!!!
Old 07-12-2008, 05:26 PM
The tanks is full Well i took the front metering block off and cleaned her up blew out all passage ways in it and the main body but still nothing. I tried changing the metering screws as well but its a no go. Is there any metering cicuits in the secondaries? It ran fine 3 days ago what is goin on!!
That lousy Holley carb cool rockin daddy Engine 30 02-29-2008 02:01 PM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
Holley throttle body Kevin45 Engine 1 06-10-2005 11:46 AM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
