Holley AED/Proform 850 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2009, 08:02 AM
I've got my 355 running!
This is in 70 Nova that I'm going to make a 20%street / 80% strip (1/8 mile) car out of.
Current 355:
Flat Top forged pistons
SCAT Crank
5.7 H Beam Rods
Victor Jr intake
MSD 6AL
Holley 750 DP
Pretty Weak Hydraulic Cam - Now Comp Cams- XTREME ENERGY 12-679-5 cam
Pretty Weak Factory heads - Now DART PRO1's 200cc.
4500 Stall Converter
Power Glide with trans brake
4.56 Gears
I'm also in the process of building a 383..
Found a carb that I'm looking at doing some trading with.
850 AED HOLLEY DOUBLE PUMPER WITH PROFORM CENTER SECTION (the guy stripped out the original AED) AND JET EXTENSIONS .078 JETS.
Your thoughts -
Is this a good carb?
Too big?
Old 06-24-2009, 08:16 AM
Well with your converter and gear as shown I would think you are going to be thrashing thie thing, and IMO it is not too big. Bigger Q's to think about... what are you trading up? Is the center section the right one for the rest of the deal? Sometimes people swap and change things out that just aren't right. Are you sure this carb is worth the swap? What price or value is your trade? It's hard to say if it's a 'good carb' or not given your description. Whenever looking at used or assembled from parts carbs it would be nice to know/see if it actually works on a running engine.
Old 06-24-2009, 08:32 AM
Good questions
The carb I'm trading is your standard 750 Holley DP and I'm giving $150. The guy has offered to put it on his car and run it.
I don't know anything about the proform center sections. Are they any good?
Old 06-24-2009, 09:01 AM
Clear me up
Originally Posted by F-BIRD'88
I have the 750 proform center section on a 700dp and it works very well.
Make sure which center body you have. 750, 850, 950. and which throttle plate you have. 1-11/16" 1-3/4" If you ahve a mismatch of parts, it won;t work well without a lot of fiddleing with the fuel curve tune.
So I should measure the center body throat diameter and compare it to the throttle plate and they both should measure the same.
Old 06-24-2009, 10:31 AM
Thats not what I said. If the various carb parts have been swapped around eg: a 850 dp body on a 950 base or 750 body on a 850 throttle base, the fuel curve will need adjustment. (metering blocks) This may be why its being offered for sale/trade.
Seriously consider working with your own 750 (with a new proform 750 center).
I found the part number for the proform 850 center body - 67107c. Do you know if proform stamps their # anywhere on their main body?
Holley Carb FUN (for Barry Grant Guy also) PutPut72 Hotrodders' Lounge 21 10-24-2008 09:35 AM
Holley 9380 850 race carb idle setting Quarter Flash Engine 7 05-01-2008 10:12 AM
Holley 850 Carburetor defference JamesRS Engine 2 04-07-2007 12:03 AM
Holley 850 CFM Vacuum Secondaries.. PITA..!! Viet Nam Vette Engine 18 04-12-2006 07:54 PM
Carb comparison Demon vs Holley DTL504 Engine 12 12-29-2004 02:53 PM
